car shuts off while driving
Old Oct 15, 2009 | 11:30 AM
black_89gt's Avatar
black_89gt
Default car shuts off while driving
My car just started doing something weird today. When I was going around a turn I pulled the steering wheel toward me a little bit and the car shut off. It started right back up though. After I started it, the stereo wasn't working, the windshield wipers wouldn't come on and the windows wouldn't roll down. but after I drove it for about 5-10 mins everything worked fine again. I got back to my apartment and parked, but when I parked I wanted to see if the car would shut off again, so I pulled the steering wheel towards me and the car shut off again. But it starts right up every time, so i don't think its anything major, it just seems like a short. Could yall please help me in diagnosing my problem?
Thanks,
black_89gt
Old Oct 15, 2009 | 11:40 AM
mattdel's Avatar
mattdel
most likely a loose connection between the ignition switch and the harness. being able to affect it by pulling the steering wheel towards you would also indicate that your column is starting to lose its tightness, and any competent inspector for state inspections will probably fail it eventually, depending upon where you live.
Old Oct 15, 2009 | 11:47 AM
black_89gt's Avatar
black_89gt
well I dont have inspections here. I don't know if it would have been the last guy that worked on the car either. I recently got the a/c fixed and heater core replaced and he f***ed up the wiring and everything, I'm not sure if it would have been his fault or not. But he did pull apart the whole dash and dropped the steering column, could it have been his fault?
Old Oct 15, 2009 | 11:59 AM
mattdel's Avatar
mattdel
anything is possible, and they are pretty brittle with age.
Old Oct 15, 2009 | 12:53 PM
black_89gt's Avatar
black_89gt
What gets pretty brittle with age? I'm thinking that it is the wiring and not the column because the stereo and windows stopped working. I guess I'll just have to take it to him or someone else to get it looked at and fixed.
Old Oct 15, 2009 | 01:03 PM
mattdel's Avatar
mattdel
both the switch and wiring get brittle, and they have a known problem with melting too, so you might find that to be an issue as well.
Old Oct 15, 2009 | 01:04 PM
bigmike73's Avatar
bigmike73
check your solenoid same thing happened to me minus the steering wheel part and the one side of my solenoid was loose. hope this helps.
Old Oct 15, 2009 | 01:53 PM
black_89gt's Avatar
black_89gt
Thanks for all the help guys
msavoia23
12
Jul 7, 2018 12:08 PM
chain
Aug 17, 2015 08:52 AM
drumhedd2005
Aug 13, 2015 09:59 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
