Throttle problems
Old Jul 15, 2005 | 11:20 AM
akatsume's Avatar
akatsume
Default Throttle problems
Hey, I still have the stock throttle body on my 88' Stang and I was about to change it today for different reasons and one especially: rough idle and overall throttle hesitation. My car has been sitting in the garage for 4 weeks becaucse I was waiting for new springs and I've had shipping troubles. A week ago, when I started the car, it began running with an unstable idle and I had prestone leak near the tranny. I checked everything and it was the heater's o-ring so it was nothing bad. Although, it didn't fix my idle problem. Yesterday, when the springs were installed, my car kept running with a weird idle and an obvious hesitation with a 1/4 throttle and a really obvious hp loss. I then decided to install my new 65mm Accufab TB and this is where I am at now. I was about to get the oldie throttle out when this **** happened: Prestone leak in the bottom of the TB. So now I have no idea how I could have a prestone leak within my intake!? Could this explain my idle and throttle hesitation? Thanks a lot!
Old Jul 15, 2005 | 11:43 AM
wildstang87's Avatar
wildstang87
Default RE: Throttle problems
check your egr spacer and gaskets.
Old Jul 15, 2005 | 11:47 AM
fordguy17's Avatar
fordguy17
it could have to do with your idle if you had an airleak at your egr spacer.
Old Jul 15, 2005 | 03:35 PM
wildstang87
well i meant the coolant leaking in the intake, the egr spacer has coolant lines running through it to cool it, and you might have a leak there, i think your idle problem will probably be something else.
Old Jul 15, 2005 | 05:11 PM
ZachW04Stang's Avatar
ZachW04Stang
You might want to invest in a vacuum guage and run some vacuum test.
Old Jul 16, 2005 | 06:06 PM
akatsume's Avatar
akatsume
I cleaned the IAC and the car's idle is much better now. Thanks for the help
Old Jul 16, 2005 | 09:51 PM
wildstang87
youre not worried about the coolant leak inside your intake??????
Old Jul 17, 2005 | 02:39 AM
akatsume's Avatar
akatsume
Not anymore There were only 2-3 drops and I realised they were in the egr spacer, not in the intake itself so no worries. I kinda got panicked when I saw some drops falling from the spacer but I realised it was nothing at all
Old Jul 17, 2005 | 03:01 AM
3stangs's Avatar
3stangs
what does IAC stand for
Old Jul 17, 2005 | 03:03 AM
3stangs's Avatar
3stangs
does it mean idle air control if so what does it look like and whear is it
