pinion angle help pleaseee
Old 11-14-2009, 12:38 PM
ctgreddy
ctgreddy's Avatar
Default pinion angle help pleaseee
Ok so I got my adjustable uppers on, and checked the pinion angle and I used this guide to do it....
http://www.vibratesoftware.com/html_...aft_Angles.htm
well my measurements were..
on the trans yoke=bubble faced the rear and the angle was 1.5, so that's a negative 1.5 angle correct?
on the rear yoke=bubble faced frontwords and the angle was 3.0 degrees so that's a positive angle correct?
if my calculations are correct I have an all together angle of 1.5 positive, and I want negative 2 correct? i drove it around and it's still wheel hoppy so i need some assisence.
ctgreddy is offline
Old 11-14-2009, 01:05 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Link is no good and you did this w/ all wheels on the ground right?
PRO50SC is offline
Old 11-14-2009, 02:10 PM
ctgreddy
ctgreddy's Avatar
Correct all the wheels were on ramps that were the same height. No Jack stands. -2 is what I'm aiming for right?
ctgreddy is offline
Old 11-14-2009, 02:50 PM
ctgreddy
ctgreddy's Avatar
ctgreddy is offline
Old 11-14-2009, 04:27 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
I can't remember what mine is set at. Been to long ago and I suffer from CRS. W/e it is, it must be right. Have you tried a search, I know I posted abot it back then. Been a while though.
PRO50SC is offline
Old 11-14-2009, 04:30 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
https://mustangforums.com/forum/5-0l...-the-rear.html
https://mustangforums.com/forum/sear...archid=1307433
One more w/ article
https://mustangforums.com/forum/1849552-post7.html
PRO50SC is offline
Old 11-14-2009, 05:06 PM
AdderMk2
Banned
AdderMk2's Avatar
http://www.baselinesuspensions.com/info/pinionangle.htm
should help as well
AdderMk2 is offline
Old 11-14-2009, 11:46 PM
Jfsram
Jfsram's Avatar
You want the pinion to point downward in relation to the driveshaft.
Jfsram is offline
mtgldr
02-03-2024 09:00 PM
baddog671
07-26-2016 01:20 PM
Gene K
10-21-2015 11:37 PM
KingRando
10-02-2015 08:06 AM
DJ Piner
09-30-2015 03:03 PM
Quick Reply: pinion angle help pleaseee
