why are my blinkers not working 91 mustang
Old Jan 27, 2010 | 10:39 PM
thestangbros's Avatar
thestangbros
Question why are my blinkers not working 91 mustang
I have a 91 Mustang and my blinkers dont work. I have checked all fuses and replaced the relay. my emergancy flashers work just not the turn signals. Not sure what to do about fixing that. Any ideas on what i should try next to fix this problem?
Old Jan 27, 2010 | 11:48 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
could have a bad switch, you need to grab a wire diagram and go point to point in the system
Old Jan 28, 2010 | 01:48 AM
tohoopty's Avatar
tohoopty
did you replace the right relay
Old Jan 28, 2010 | 02:24 AM
86 5.0L's Avatar
86 5.0L
also check your blinker fluid, most of the time, nobody bothers to check and replace it
Old Jan 28, 2010 | 09:00 PM
5.0stang.ryan's Avatar
5.0stang.ryan
Hey had the very same problem with my 90 gt. There is a connector for the four way lights in the front. The signals and flashers are on a different connector. The connector u need to look at is next to the battery. Look at the color of the wires going into the signal bulbs. Match the colors up with the connector. I had to wrap a zip tie around both ends of the connector to keep it together. After year of wear and tear the clip that holds the two parts of the connector together wear out and no longer hold the peices together. Hope this helps
Old Jan 28, 2010 | 09:08 PM
thestangbros
thanks bud i am going to try to find what your talking about. ill let you know if i have and success with that. i hope its that simple to fix.
Old Jan 28, 2010 | 09:47 PM
5.0stang.ryan
No problem if it helps the connector is round.
Old Jan 28, 2010 | 11:13 PM
im_stuck_in_iraq's Avatar
im_stuck_in_iraq
LMAO ha ha ha
Old Jan 29, 2010 | 08:18 PM
thestangbros
i know the flasher relay is on the fuse panel. do u know where the blinker relay is?
Old Jan 29, 2010 | 10:17 PM
tohoopty's Avatar
tohoopty
on my 87 its by the steering column but not sure on a 91
