Limiting Factor
Hi Guys...Newbie here.
This is what I have:
91lx 347 NA, C4-4200 stall with transbrake, 4.10,s, welds with skinny's and 9" slicks, Eibach front and back springs with drag launch kit, subframe and uppers and lowers non-adj installed.
Engine: 347 with 10.3-1 comp, edlel pro Rpm 170cc(I think), airgap intake, QF 750 with man secondary, bbk shorty's with h-pipe, no mufflers.
I launch at 3400 rpm, best time ever was a 11.91 at 111ish mph, 60's in the 1.65-1.69 range. alt 2500 air about the same
So my question is whats limiting me..heads and Intake?
heads are way to small. i tried running afr 165 heads on a 331 and even with a sc it fell on its face at 4500rwhp. 185-190 is the smallest head id run on that motor. fwiw, i run 205cc heads on my 331. after you get some good heads, get a custom cam. then get a wider slick so you can launch the car at a higher rpm. if the car doesnt hook with a wider tire (after the heads cam upgrade) its time for more suspension work
Is there anyway I can tell what cc heads I have without pulling them off? I can't find a part number on the outside of them anywhere. Now if for some reason I have the 190cc heads would a better intake help? The cam I have is listed a few posts back.
Ok, that clears that up...thanks, Now if I go with 205's do I have to worry about piston / valve clearance? Or is that something that I should measure using the edel rpms first. Should I keep the air gap or turf it as well, I would rather buy a better intake then have to port it.
