how do i get the fuel out of the lines and back in the tank so i can pull the lower intake...
and is there a kit so i can replace the vacuum lines, because the old ones snapped at a touch...<edited><editID>bmorrisj</editID><editDate>37949.6542013889</editDate></edited>
To depressureize your fuel system you havta pull the plug from the fuel pump reseter. which should be located behind the panel in the hatch... The panel with a black plug in it. Once you unplug that you simply start your car and let it run till it stalls then its depressurized
ah the car has not been ran for two days, and it looks like there is a bbk afpr on there, im getting back into it tomorrow morning...im almost there...
