Nitrous HELP!!!!
Old Jun 5, 2010 | 01:17 PM
TurboJones's Avatar
TurboJones
Default Nitrous HELP!!!!
Ok i am new to nitrous so i need a little help tuning my 5.0. I have a NOS Sniper Wet kit that due to the jet combo i am runing a 125shot. I just tried it for the first time and it was very weak after 3 shots the car started runing like ****! I got home pulled a plug and it was black as hell and rounded, So im running way to much fuel according to my chart. I recently purchased the car it has bbkshorty headers, bbk 70mm tb, bbk tb spacer, c&L mass air flow and a bbk fuel pressure reg w a gauge on the back. Guy said it has 24lb injectors and it looks like they have been in the tank so who knows what fuel pump? I need to know from someone what to run my fuel pressure to and if i need to mess with my timing at all? Someone help lol please i dont want to see my pistons beside me while im driving
Old Jun 5, 2010 | 04:57 PM
aleXander2648's Avatar
aleXander2648
You need to set the timing for juice. Less timing advance and high octane fuel.
Old Jun 5, 2010 | 07:01 PM
luckythirteen13's Avatar
luckythirteen13
what was your bottle pressure? if the bottle is cold the pressure will drop which means less nitrous per shot yet the fuel pressure stays the same.
pull a couple degrees of timing for the nitrous.
i would never spray nitrous without knowing what fuel pump is in the tank.
Old Jun 6, 2010 | 03:47 PM
nitrous_bob's Avatar
nitrous_bob
yeah at least use a guage off the schrader to watch it. fp is about the most important thing you need to worry about
on 125 jets i would run 10-12* timing depending how high octane your using, and the ambient conditions
what plug gap ? i like .042" for smack
and what do you mean the plug is rounded??? some of it is gone??? your gonna melt a piston doing that. or i just dont understand what your talking about
36-38 psi with vac on is good so about 42 psi WOT
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
