I'm looking to do a compression test and a leak down test on my 90 mustang. The problem is that I have gt40 heads and the the testers do no screw in. Is there a certain adapter that I need or am I doing something wrong?
any compression tester kit should have a bunch of adapters to it. you might be missing some, so i'd suggest contacting the company of the product you own.
With a compression test you can find out which cylinders are low on compression with a leak down test you can use the information from compression test to look deeper into the bastard cylinders and determine if you have a valve blowing by or a worn rings.
Yes compression testers should have about 2-3 different thread adapters the tfs heads like most aluminum heads have a 14mm thread and the cast heads have the 5/8 thread!
thats why it worked with your trickflow heads and not your cast heads!
I may be reading too deep into your post but why would you need to do both?
If you have access to a leak down test. That should tell you whatever you need to know.
you start with compression test, if you get a lower than normal reading, than you move to a leak down test to narrow it to a valve issue or ring issue.
