5.0 to 4.6 swap
Old 07-24-2010, 11:55 AM
94gtcoupe
94gtcoupe's Avatar
Question 5.0 to 4.6 swap
looking for a little advice search feature didnt help much...
i have the option to buy a built 4.6 from a friend for a good price and was considering the swap, tools and mechanical know how are not a problem. just want to know what else i'll need other than the motor and more than likely the trans. (not 100% if my t5 will bolt up) motor comes with harness ecu and acessories...
so what else will i need
94gtcoupe is offline
Old 07-24-2010, 12:59 PM
AdderMk2
Banned
AdderMk2's Avatar
K-member, transmission, body harness, fuel system, returnless fuel system electronics...
far too much work to justify the increased cost of modifying the engine...
AdderMk2 is offline
Old 07-25-2010, 08:34 AM
aode08
aode08's Avatar
Do you want more power with your SN-95?
aode08 is offline
Old 07-25-2010, 02:49 PM
94ford5liter
94ford5liter's Avatar
why would you want to go to a 4.6 in the first place? Unless you are talking about a 03-04 cobra engine or something that actually makes good power.
94ford5liter is offline
Old 07-25-2010, 10:30 PM
w8less
w8less's Avatar
DOHC or not at all
w8less is offline
Old 07-25-2010, 10:32 PM
w8less
w8less's Avatar
oh yea quicktime makes a bellhousing so use your t5
w8less is offline
Old 07-26-2010, 06:37 PM
94gtcoupe
94gtcoupe's Avatar
the reason i want to swap is because the power i want is unattainable with a stock 5.0 block... the motor im considering made 475whp and was built by a good friend.
the work is not a problem im a tech. at a local ford dealership just wasnt sure exactly what all i would need to change to pull off the swap
i knew i would need a kmember and a bigger fuel pump, just forgot to mention that, but y would i need a body harness and a returnless fuel system when i know that all fuel injected motors have a return line
Old 07-26-2010, 06:44 PM
AdderMk2
Banned
AdderMk2's Avatar
then you should learn that you are quite friggin wrong. Depending on the year the engine came out of, it could be exactly that.
i know we used to be friends, but you seem to not know **** for being a "tech"
Just something for you to look into IF you decide to build a fuel system. You will need 96-98 fuel system parts, or aftermarket ****
AdderMk2 is offline
Old 07-26-2010, 07:11 PM
aode08
aode08's Avatar
building 475 rwhp with a 4.6 is not gonna work out for you without spending a million dollars.
The forged internals, heads , supercharger or turbo, its not going to do it N/A, transmission conversion and upgrades etc will easily exceed $10,000 with a modular, providing you do the labor.
You can swap in a Dart Block , with 427 Stroker kit,351w conversion items, built tranny and have a 427 for 26+% less than that.
Or supercharging a 331 or 347 /355 Forged Assembly in a dart block with tune and built tranny, axles.
aode08 is offline
Old 07-26-2010, 08:03 PM
94gtcoupe
94gtcoupe's Avatar
im not here to debate if a 4.6 can or cant do, i now remember y i left here the first time, every one wants to tell you not to do **** rather than answer the questions asked, i watched the car make 475 no its not n/a... and no the turbos dont come with it thats a later project, i know all the modifications needing to be done to the body and suspension, yes i could build a 427 but between the block internals and top end its not going to b any cheaper considering ill still have to do most of the same modifications to ensure the cars doesnt pull itsself apart
Quick Reply: 5.0 to 4.6 swap
