Trickflow Intake Problems
Old Jul 31, 2010 | 09:15 PM
RTW0223's Avatar
RTW0223
Default Trickflow Intake Problems
Hey guys. Just installed the Trickflow upper and lower street heat intake on my 92 LX 5.0, along with the BBk Edelbrock 70mm TB and EGR spacer. Only problem is.... antifreeze is leaking from the lower intake. Any solutions? And if anyone is located near northern MD i could use some help
Old Jul 31, 2010 | 09:20 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
remove the intake Ryan and reseal it,with that intake you'll need to use the fel-pro 1250 gasket, which I assume you did?? the ports on the tfs intake are larger than the stock ports on the heads , so it is key to match a gasket to the lower intake, if you catch my drift?? i OFTEN PLACE SEALER around the water jackets on the underside of the gasket and topside occasionally, never had a leak done in this manner
Old Jul 31, 2010 | 09:36 PM
RTW0223's Avatar
RTW0223
yes i have felpro 1250's on there
Old Jul 31, 2010 | 09:43 PM
RTW0223's Avatar
RTW0223
and oh wow i just noticed it was you Mike, umm yeah i have the fel-pro 1250 gaskets on there. what sealer did you use and you put it right on the gasket??
Old Jul 31, 2010 | 09:56 PM
mjr46's Avatar
mjr46
sorry to see you having such a hard time with it Ryan. anyway yup , right on the back side of the gasket, they say you don't need to around the blue printoseal on the topside but I do it anyway, and I only do it around the waterjackets and not the intake ports, and I don't use the end cork gaskets, I run a thick bead of Permatex's "the right stuff" that stuff is like super glue!!! torque in sequence according to manufactorer specs, I torque the bolts often in three stages, first stage to around 7-8 ft lbs, second to around 14-15 then third to around 21-23 ft lbs, that way it is an even process.
Old Jul 31, 2010 | 10:05 PM
RTW0223's Avatar
RTW0223
you used the permatex on the gaskets too?
and i found torque ratings of
Step 1 96 in/lbs
--Step 2 16ft/lbs
--Step 3 23-25 ft/lbs
?? hmm..
and yeah this has been a 2 week long process ((
Old Jul 31, 2010 | 10:11 PM
mjr46's Avatar
mjr46
yup, around all the water jackets , top and bottom sides, not one leak from my 89 yet and it has a eddy rpm ii on it , I don't use sealer around the intake ports at all, if I do anything I spray some high tack on the back side of the gaskets only, some say I go overkill, but yet to have a leak done in such manner
Old Jul 31, 2010 | 10:13 PM
RTW0223's Avatar
RTW0223
alright. i will have to get some at advanced auto. and which torque specs should i use?
mjr46's Avatar
mjr46
Step 1 96 in/lbs
--Step 2 16ft/lbs
basically the same manner I do it just do it in the three stages and after the third stage let it sit for 15-20 min then recheck torque, and go slow and don't muscle the lower or upper intake bolts so as to not break any this time around
Old Jul 31, 2010 | 10:15 PM
RTW0223's Avatar
RTW0223
yeah its just for the first stage u said 7-8 but this says 96, so double checking
