Idle problem...
Old Sep 15, 2010 | 10:20 PM
19stang88's Avatar
19stang88
base timing is 10 degrees. Anything above that requires higher octane fuel
Old Sep 17, 2010 | 10:08 AM
rprice180's Avatar
rprice180
Cool
Did you try the IAC valve? that might be a place to start.
Old Sep 17, 2010 | 01:12 PM
)\/(!&\/3|'s Avatar
)\/(!&\/3|
AMEN issue solved... BUT I got other problem, the car leaves white smoke... Sometimes without acceleration it doesn't do it, other times it does, when acceleration is applied it leaves a LOT of smoke!!!! I first believe that it was the timing but now I believe it wasn't, because now its at time and it makes the best idle that I have ever hear!!
What it can be?
It maybe the valve seals?
Any idea? Thanks!!
Old Sep 17, 2010 | 01:13 PM
)\/(!&\/3|'s Avatar
)\/(!&\/3|
Thanks now its at 10 deegres and its working like a 2011 Mustang, its was at 30 deegre BTDC!!!
Old Sep 17, 2010 | 03:28 PM
19stang88's Avatar
19stang88
DANG 30! How did it run? When do you get the white smoke? It is in the morning or all the time?
Old Sep 17, 2010 | 03:40 PM
)\/(!&\/3|'s Avatar
)\/(!&\/3|
Its all the time, here in Puerto Rico the temperature isn't enough to make it do it even in morning, sometimes in winter it does but its almost never.
I am pretty sure that it is oil that white smoke.
Any idea?
Old Sep 17, 2010 | 03:48 PM
)\/(!&\/3|'s Avatar
)\/(!&\/3|
One thing that I noticed was when I was checking the compression the sparks have an oil smell. I don't know if that in a Mustang engine is normal, because in rotor engine it have to smell like that.
And in the throttle body have a little oil before the throttle.
I don't know if this is normal or what? ooo and i believe that I haven't say it I replace the pcv valve to check if it stop shooting withe smoke and it does it a little less but it still...
Old Sep 19, 2010 | 08:43 PM
)\/(!&\/3|'s Avatar
)\/(!&\/3|
Anyone?
Old Oct 3, 2010 | 11:56 PM
)\/(!&\/3|'s Avatar
)\/(!&\/3|
no one??!?!?!
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
MacSerio
Sep 27, 2015 01:05 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
