Done the disc conversion?
Just wondering if any of you have done the 4 wheel disc/5 lug conversion before. I want to do it myself, so I was wondering if it is tough to do. I am going to do the SN95 Cobra kit.
Please let me know what you thought about it. Should be easy except I have never bled brakes before.
John
John
find a 88 t-bird turbo coupe rear end its a 8.8 and bolts right in 1 inch wider but has not been a problem and i run 245 45 17.It also has 3.55 or 3.73 unless mine had a gear change before i got.And had a local shop weld and drill axles for five bolt only cost me $350 for all.Hope this helps it only took 1 hour to install 2 days to fine tune proportioning valve
Thanks for the help though. Not sure I want to do the T-bird route, I have a built rear end I don't want to get rid of.
Saint
Went a different route. I got the entire 03 Cobra brake system off of a wrecked one for less than half the money of the Ford kit. It's refurbished too, I just need to paint the calipers.
I want to get this wheel/tire combo http://www.cruizinconceptswholesale....ANDTIREPACKAGE I know what I need to do for the rears to fit, but will a 255 tire on a 17x9 wheel fit on the front without rubbing?
It will but you will get rubbing when turned full clock. Nothing a hammer can't fix though. I just pounded in the fender liner a little. Worked like a charm.
And how are you going to get the IRS to work on a fox?
