Finally took a fuel pres gauge to my car, can you say horrible?
That's right.
Hooked that bad boy up and BAM! Car running with vacuum hooked up to fuel regulator I got 25-psi. Unplugged the vacuum and I got 34-psi. Now isn't that lovely? |
Sounds like a fuel filter and fuel pump replacement....you have been having issues I presume?
Having no "real" problems at all actually. Besides running on the lean side. Car starts right up and drives right off.
I just figured I'd check it out. The PO said a hi-volume pump was installed but, lol. |
i'd replace the regulator before replacing the pump
What kind of pressure am I suppose to have with a stock pump?
Same pressure as a aftermarket pump puts out. Aftermarket fuel pumps flow more per hour, not more pressure. As adder said, try the regulator first.
I would also check the little "s" shape hose in the fuel pump, before i replaced mine, i was leaking from there.
