New clutch minor slip
Old Feb 25, 2011 | 11:53 AM
5.0lxstocktrnk's Avatar
5.0lxstocktrnk
Default New clutch minor slip
hey guys I have a question about my car well the problem is my car seems to have slight clutch slippage when the engine is under load. The car has a new clutch(stock) but we used the old adjustable clutch cable in it. I think the clutch cable needs to be adjusted but anyway the car has a new motor in it maybe 3 weeks old...mild motor with gt-40 irons and mild cam. car shifts fine though..lol but maybe too easy...feels like driving a caddy..smooth but under load engines revs nice but car barely goes anyware..my father says its slipping.. what u guys think. I'll appreciate your input.
Old Feb 25, 2011 | 02:13 PM
Js88lx's Avatar
Js88lx
Well i hope whoever installed it made sure the flywheel and clutch disk where Super Clean with no oil on them! I dont think your clutch cable is causing it...
Old Feb 25, 2011 | 03:44 PM
5.0lxstocktrnk
wow now that would cause that?....
Old Feb 25, 2011 | 03:50 PM
1987gt40ttop's Avatar
1987gt40ttop
deff. would cause it thats like the number one thing that most people forget, even the oils from your fingers and your skin can make a clutch slip thats why they make a clutch disc tool to help line it up and so you dont have to touch it and get it dirty
Old Feb 25, 2011 | 04:01 PM
5.0lxstocktrnk
well the mechanic that installed it did use the clutch tool though...thats weird because with the orginal motor and clutch was that was in it were doing the same with but it was hard to get in gear then so I believe that was the clutch but now its weird. I have a gt hatchback that has a similiar problem to this a long time ago where the clutch pedal would have to be raised all the way up for the car to engage, this notch I have now does the same thing...but anyways to fix the gt we notices the bushing on the clutch cable under the hood on the firewall was being pulled too tight and was warn out so we replace the cable and i didnt have that problem anymore.. but the guy that had this notch before me put like header wrap all of the clutch cable so I cant tell with this car.
Old Feb 26, 2011 | 08:37 PM
5.0lxstocktrnk
problem fixed...
Old Feb 26, 2011 | 10:37 PM
1987gt40ttop
what was it? cable adjustment?
Old Feb 27, 2011 | 07:31 AM
5.0lxstocktrnk
Well let me put it like this I'm a little embarrassed to say this but it had nothing to the due with the clutch or clutch cable at all. I forgot to the mention that after installation of the new engine I've had some distributor problems. The Distr. wouldnt say down. It even tore the gear up on one but didnt hurt the engine but anyways to make a long story short. the engine's timing wasnt properly set so I got a timing light on her last night and set her 12 degrees for performance and put some kyb gas struts on the front b/c my front end rode horrible. one of the originally was busted. Well she runs alot better now, sorry if i made anyone think to hard when it was another issue.
Old Feb 27, 2011 | 04:25 PM
Js88lx's Avatar
Js88lx
Glad you got it all worked out!!
Thunderball
15
Nov 22, 2015 11:49 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
TCStangerv6
Oct 11, 2015 05:57 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
