need help
Old Jun 21, 2011 | 11:28 PM
caspers_mustang's Avatar
caspers_mustang
Default need help
i just got this 91 mustang gt. originally it was an automatic car but sometime before i purchased it someone made it a stick shift. i don't know what they were thinking but the put a 4 speed in it instead of a 5 speed. i have a problem with it though because the car wont shift when you push in the clutch and the car is on. But while its off you can put it in any gear. i checked the clutch and its fine, so is the fly wheel and the tranny is to. my only guess is that the clutch cable maybe incorrect or the pressure plate is bad.
any guess what it is?
Old Jun 22, 2011 | 09:22 AM
AdderMk2's Avatar
AdderMk2
Banned
TOB, clutch fork, or cable.
Old Jun 22, 2011 | 04:49 PM
nitrous_bob's Avatar
nitrous_bob
did it work when u bought it...now it doesnt ??
did you adjust the cable ?
can you put in 1st then start it and at least drive in 1st ? to see when it engages/disengages ?? when u push the pedal in ?
Old Jun 22, 2011 | 05:22 PM
lxman1's Avatar
lxman1
For some reason, it is not fully releasing the clutch. Obviously for one of the reasons mentioned above.
Old Jun 22, 2011 | 05:29 PM
caspers_mustang
it did the same when i first got it. and yeah it will start in 1st but then i have to shift without using the clutch and i can get into all the gears. I ve only driven it around the block though because i hope its not the trans.
Old Jun 22, 2011 | 10:02 PM
nitrous_bob
ok...have you adjusted the cable at all ?
even the stocker will adjust...pull out on the pedal and then press with your foot. do it a few times
Old Jun 23, 2011 | 12:13 AM
caspers_mustang
i checked the cable and it works because it pulls the fork back pretty good so i dont know what it could be
Old Jul 13, 2011 | 11:27 PM
caspers_mustang
UPDATE I got a steeda cable adjuster kit that includes the cable,firewall adjuster, and pedal adjuster and what do you know it freakin works now.
