Installing gauges...please hel
Old Dec 6, 2003 | 03:51 PM
FiveOhNo's Avatar
FiveOhNo
Default Installing gauges...please hel
ok, so today i got the "gauge cage" from autometer along with a mechanical water temp gauge and a voltmeter. i was just wondering- 1)does anybody know the best way to wire the lights? and...2)for the water temp., where would i put the fitting (mechanical gauge) in the block? is therea certain place to do it? thanks again...cya
Old Dec 6, 2003 | 05:39 PM
Quik's Avatar
Quik
all your sensors should go into the existing spots.
Old Dec 6, 2003 | 07:17 PM
FiveOhNo's Avatar
FiveOhNo
alright, thanks. what about the lighting though? i found that if you spliced into any other lights they just dim really bad (ie-gauge cluster, a/c cluster).</P>
Old Dec 6, 2003 | 08:00 PM
FiveOhNo's Avatar
FiveOhNo
ok...so i'm looking for the original water temp sensor...can't find it...i just bought the car not too long ago so i haven't bought a haynes manual or whatever for it...any help would be great...thanks<IMG src=smileys/smiley4.gif border="0">
Old Dec 7, 2003 | 12:32 AM
Buzzstang's Avatar
Buzzstang
it should be in the lower intake towards the front. the lights just hook them up in the fuse panel it is the easiest.
Old Dec 7, 2003 | 06:21 AM
O 16581 72452 5's Avatar
O 16581 72452 5
Wire them in with the illumination wire of your CD player/stereo.
The ECU fuse would be the easiest (not sure what other fuses are in Mustangs, i don't own one), but the lights will always be on (with the key turned to the "on" postition of course). <edited><editID>O 16581 72452 5</editID><editDate>37962.183275463</editDate></edited>
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
