please help !!!!!!!!!!!!
Old Jan 20, 2012 | 01:43 PM
bobbyt's Avatar
bobbyt
Default please help !!!!!!!!!!!!
hi all well i have a 94 mustang gt and i took the upperintake off to replace some vacuum hoses cleaned the tb , aic , egr and replaced gaskets then put all back together at idle she runs fine i can rev it up and it sounds great but when i go to drive it it spitters and sputters almost as if a plug fouled i checked all plugs and wires ect i am stumped any ideas out there any advise would be better than no advise thank you it ran fine before i took it all apart
Old Jan 20, 2012 | 02:05 PM
mattdel's Avatar
mattdel
Did you forget to hookup the vacuum to the fuel pressure regulator?
Old Jan 20, 2012 | 02:13 PM
bobbyt's Avatar
bobbyt
its connected
Old Jan 20, 2012 | 02:33 PM
mattdel's Avatar
mattdel
Be sure all your routing is correct. Some of these lines are switched vacuum, can mess with things if they're not correct.
Old Jan 20, 2012 | 05:04 PM
jojobanks's Avatar
jojobanks
did you replace your intake manifold gasket? Might also try spraying starter fluid around the lines/intake to see if maybe one of the vac lines cracked or split while you were doing this.
Old Jan 21, 2012 | 11:32 PM
bobbyt's Avatar
bobbyt
i checked all vaccum hoses and sprayed carb and choke cleaner on all the hoses everything seems fine and its still do it could it be a cracked upper intake i see no visable cracks at all could it be on the inside
Old Jan 21, 2012 | 11:38 PM
bobbyt's Avatar
bobbyt
and yes i did change the gasket
Old Jan 22, 2012 | 11:11 AM
mattdel's Avatar
mattdel
You're just gonna have to take the intake off again and look for things that are out of place. Something didn't go back together correctly.
