Four eye hid' s or upgrade bulbs
Old Apr 4, 2012 | 10:00 PM
oldfordisbetter's Avatar
oldfordisbetter
Default Four eye hid' s or upgrade bulbs
My 85 gt has the 4 headlights. There is water on inside. And are kinda dim. Is there a hid kit for them or am i limited to swapping out just the bulbs? IF SO WHAT ARE THE BULB#
Old Apr 4, 2012 | 11:21 PM
luckythirteen13's Avatar
luckythirteen13
I'm sure they make an hid bulb for your car. If you don't get the bulb size here just contact the hid manufacturer of choice and ask them. I think my 92 uses h3. I'll confirm before I order tho
Old Apr 5, 2012 | 03:24 AM
mustangGT86_05's Avatar
mustangGT86_05
Never heard of the 4 argh thread hijacked lights lmao but factory the cars came with sealed beam headlamps. You can convert to h4 and h1 bulbs, just make sure you get the right stuff (high and low lenses are different) and with a beam pattern, none of the euro-clear junk. From there if you wanted to upgrade to hid you would need h4 and h1 kits
Old Apr 6, 2012 | 05:05 AM
oldfordisbetter
sealed beam? i i cant just pop out the bulbs i got to replace whole unit?
Old Apr 6, 2012 | 07:05 AM
MrPack91's Avatar
MrPack91
Maybe i'm wrong here but my local autozone had a book telling me exactly what kind of bulb to get for the 91 so i'd imagine your local autozone has the same thing.
Old Apr 6, 2012 | 09:00 AM
Five0hFox's Avatar
Five0hFox
Yes with sealed beam you replace the whole unit, however they're a lot cheaper than replacing a composite headlight.
Old Apr 6, 2012 | 02:13 PM
mustangGT86_05
A whole composite lamp maybe, but compared to the bulbs they aren't. You are also limited as far as options and beam patterns, so I always upgrade. Keep in mind if you install h1 bulbs you gotta clip the factory plug and splice in new wires. It isn't hard just a heads up
Old Apr 6, 2012 | 09:39 PM
oldfordisbetter
ok anything from ebay any good?
like these
http://www.ebay.com/itm/4x6-HALOGEN-...#ht_1072wt_952
Old Apr 6, 2012 | 10:08 PM
Leona74's Avatar
Leona74
Old Apr 6, 2012 | 10:43 PM
mustangGT86_05
like these
No, do NOT get those. Look into autopals, I have ran them on 3 different cars, they have a very good beam pattern on them and are reasonably priced. I will find some for you here in a bit
