Plenum Gasket
Old Sep 24, 2005 | 04:29 PM
JohnnyCat281's Avatar
JohnnyCat281
Default Plenum Gasket
My plenum gasket was bad when I got the car, so I decided to start the work on this car by changing that. I picked up a Haynes manuel, and it helped a little bit. I got the upper intake off and now I got the old gasket off. I have a brand new one, but my question is, is there a sealent im supposed to put on the gasket when I put it on? It seems like there should be some gasket sealent or something, but I don't know. Pretty new to engine work, so don't be too harsh
Old Sep 24, 2005 | 06:11 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: Plenum Gasket
if your only changing the gasket between the upper and lower, then no, there is no need for silicone. the gasket will be fine
Old Sep 24, 2005 | 06:57 PM
95whitecobra's Avatar
95whitecobra
I would definately not use any silicone or anything like that. I have seen gasket adhesive used. this is a thin spray that holds gasket in place when you're mounting the top piece.
Old Sep 24, 2005 | 08:30 PM
JohnnyCat281
THanks guys, I just finished up. Runs nice!
Oct 26, 2015 05:01 PM
Dathan
Oct 5, 2015 05:52 AM
wraith777
Sep 28, 2015 10:49 AM
Demodulates
Sep 18, 2015 11:14 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
