sad day in my 5.0s life
for some time now ive had hard starting. well sum it up found out blocks shot. wont hold any compression. im reading anywhere from 30 to 60psi which is way low. so good buy budget buildup hello large cubes. so my loss is going ot be your gains. my topend is forsale
tall valve covers...$25......sold summit double roller timing chain...$25 svo 1.72 Roller rockers for pedestal heads...$150......................sold Gt40P heads with .542 TF springs, milled, ported, valve job...$300.........sold GT40E ported intake with 1' heat spacer...$200 BBK unequal shorty headers...$75 BBK OR H pipe....$75 summit high flow water pump...$50 B&M AOD nonlockup 3000 holeshot converter...$200 Pro billet servo for AOD...$50...........sold ARP head bolts...$30 TFS1 cam...$100 ......sold vfast dont move this, im very pissed off right now since i couldnt get any runs this year also very well possibly my FRPP 30# could be for sale also, along with my 70mmtb/spacer,also poly motor mounts and canton oil pan, all depends on the motor i go with |
RE: sad day in my 5.0s life
reason so cheap, i dont Fawking care, i want it all gone. im starting fresh and going large cubes
also cam has maybe 5minutes of run time
heads just been rebuilt and etc no miles just minutes on everything on topend, im going large probably a 351based motor. probably a 408 stroker |
Hey Quik I feel bad, but it'll be a new beginning for your car and although it may be a little longer before you can get it done it will turn out AWESOME in the long run if you decide to go with the 408 :D.
great oppertunity for a joke like this.....priceless.
[sm=joke.gif] |
I'm sorry to hear that dude, I've been in your position, it sucks[:@]
here are some pics of the setup
sorry to hear that man. that sux. but, sounds like you got a good set of plans for a new engine, so, good luck, and let us know about it when u get it going
sorry to hear your troubles but, think of the day you start the new one ( probly be steering with your pants!)
just looked at a 392ci...fawk almost 7k for that motor.
