Bad IAC?
After I drive for a while and I come to a stop my idle is around 1700...if I turn the car off and start it back up it idles fine. But then once I start driving and come to a stop again it will idle high. Doesn't always do it though. If I unplug the iac with the car running it doesn't change the idle or anything
pull the iac off and get some cleaner and clean it out. If cleaning it doesnt clear it up then you may think about replacing it.
Here is somthing else to look at though, check all your vacuum lines to be sure one isnt cracked or loose.
KingRando
Oct 2, 2015 08:06 AM
