loss of power under high rpms
Old Oct 17, 2012 | 05:06 PM
gyouska's Avatar
gyouska
Default loss of power under high rpms
My car seems to be losing power when i step on the gas really hard. It idles fine and will accelerate slowly quite well but when I step on the gas and it hits around 3500 rpm it is very jumpy as it continues higher and sometimes it will even cut back on me. there is also a slight rattle occasionally i have noticed when the rpms jump around or stutter. I have adjusted timing and replaced igntion coil i have all new plugs and wires not sure what else to check.
also it seems to be the worst during the morning after it gets warmed up it often will run fine.
Old Oct 17, 2012 | 05:09 PM
mattdel's Avatar
mattdel
Check timing at that RPM
Old Oct 17, 2012 | 05:37 PM
gyouska's Avatar
gyouska
what should it be at?
Old Oct 17, 2012 | 06:41 PM
mattdel's Avatar
mattdel
Somewhere in the 30-40 degree range, I'm more concerned with whether it's stable or not.
Old Oct 17, 2012 | 07:34 PM
gyouska's Avatar
gyouska
alright ill give it a look thanks!
Old Oct 17, 2012 | 09:08 PM
gyouska's Avatar
gyouska
do you think it could be a fuel pressure problem?
Old Oct 18, 2012 | 07:35 PM
mattdel's Avatar
mattdel
Maybe
Old Oct 18, 2012 | 08:29 PM
gyouska's Avatar
gyouska
im not going to be able to use my friends timing light anytime soon so is there any other things i could check in the meantime?
also im pretty sure the timing is not going to be stable because the rpms are jumpy so it wont look stable. and also i dont always have this problem sometimes it will run just fine.
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
uedlose
Sep 10, 2015 03:30 PM
zanemoseley
Sep 6, 2015 12:58 PM
