Engine Stalling
Old Sep 29, 2005 | 11:32 AM
CobraR4's Avatar
CobraR4
Default Engine Stalling
Welp thanks for everyone's help. I spareyed around each injector, between the intake manifolds, with carb cleaner, and nutting at all happened. I checked every vacum line, and there good. This car has a mind of its own, some days it runs great, other days it runs crappy, is there anything else i should check, should I change my 02 sensors. Im desperate
thanks
-CobraR4
Old Sep 29, 2005 | 12:01 PM
stanglx2002's Avatar
stanglx2002
Default RE: Engine Stalling
clean the IAC and the MAF. Reset the TPS and the computer. Also have you checked your PCV valve and screen
Old Sep 29, 2005 | 12:06 PM
CobraR4's Avatar
CobraR4
show me a picture of the engine, and point all this stuff out please lol. How do I reset the computer....
Old Sep 29, 2005 | 12:10 PM
CobraR4's Avatar
CobraR4
also what do I check my mass flow sensor for,
Old Sep 29, 2005 | 12:32 PM
Tims 88GT's Avatar
Tims 88GT
ok to reset the computer pull your ground cable off before you go eat dinner or something so it sits for 20min or so, reset the tps and see what that dose.
If it dose not help, pull your pvc valve out it is located in the lower manifold all the way in the back between the fire wall and the manifold. it should rattle when you pull it out.
Then like stanglx2002 said clean the iac and the maf.
Old Sep 29, 2005 | 01:46 PM
stanglx2002
the IAC in on the front of the tb and you take the 2 bolts off and clean it with carb or tb cleaner and get a new gasket for it and put it back on. The MAF the sensor between the intake tube and the fender tube on your CAI. Unscrew the sensor and be careful with the wires and scray tb or carb cleaner on the wires and use a Q-tip and lightly clean the wires off. Its a good idea to just replace the PCV valve and screen that is in the lower intake behind the upper intake. After you have done all of this reset the computer
Old Sep 29, 2005 | 01:57 PM
CobraR4's Avatar
CobraR4
okie, lol, i cleaned my IAC once before. Is it a possibilty that it could be the 02 sensors? Im going to put the scaner up to it tomorrow when I get it back from auto body shop. thanks
-CobraR4
Old Sep 29, 2005 | 01:59 PM
stanglx2002
what is your idle set at
Old Sep 29, 2005 | 02:03 PM
CobraR4's Avatar
CobraR4
mhmm it goes up and down, its rough, proble 600-900 rpm.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
TfcCDR
Sep 14, 2015 12:08 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
