pulled oil pan, found this..
Old Jul 27, 2013 | 08:30 PM
Goosepoop302's Avatar
Goosepoop302
Default pulled oil pan, found this..
anyone ID these?
Attached Thumbnails pulled oil pan, found this..-img_20130727_202307.jpg   pulled oil pan, found this..-img_20130727_202312.jpg
Old Jul 27, 2013 | 10:13 PM
mattdel's Avatar
mattdel
Be willing to bet they're internal to the oil pump.
Old Jul 27, 2013 | 10:37 PM
darkmach1's Avatar
darkmach1
Im going with oil filter pressure bypass valve. What oil filter do you use OP?
Old Jul 27, 2013 | 11:12 PM
Goosepoop302
Im hoping they are internal to the pump...would be an easy find and fix with a new pump. I hate to say I think its a fram ><
Old Jul 27, 2013 | 11:13 PM
Goosepoop302
if you see my thread about the distributer gear it may explain more possible causes... I had a oil pump seize and snap the shaft to the distributer.
Old Jul 28, 2013 | 11:40 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
check the pump / pull it, replace it as well as get a good filter, fl1-a is all I use
Old Jul 28, 2013 | 11:54 AM
Goosepoop302
pump is being replaced. a small wire from the top of a lifter infiltrated t oil pump screen, jammed the pump, snapped the rod to the dizzy and shut down the car.
I am replacing the pump, oil pickup (afraid some pieces remain in it) oil shaft and maybe the distributer as well.
Attached Thumbnails pulled oil pan, found this..-img_20130727_195042.jpg   pulled oil pan, found this..-img_20130727_195109.jpg
Old Jul 28, 2013 | 05:55 PM
mjr46's Avatar
mjr46
replace your lifters as well if one broke, more may in the future
Old Jul 28, 2013 | 08:36 PM
Duncan_GT's Avatar
Duncan_GT
At least you broke the roll pin in the distributor and shut it down vs seizing the pump and spinning rod/main bearings. You got the lesser of two evils lol
Old Jul 28, 2013 | 10:43 PM
Goosepoop302
Well the oil pump sending units rod snapped.. What rod and bearings are you referring to
