Idel problems
Old Sep 25, 2013 | 06:08 PM
olddadwitsend's Avatar
olddadwitsend
Default Idel problems
This is a old dad with a 95 gt 5.0 car sat up for several years.complete motor rebuild. I have changed tps iacv temp sensor if you don't put your foot in it idels fine.If you get on it (not real hard) it wount drop back below 2000 it will eventually does drop to 700.Anyone that has a idea please respond.
Old Sep 25, 2013 | 06:38 PM
88 orangepeel notch's Avatar
88 orangepeel notch
So the idle will hang at 2000 rpm then drop to 700 when you come to a stop. How long does it hang at 2k? And is this a manual or auto?
Old Sep 25, 2013 | 06:45 PM
dawson1112's Avatar
dawson1112
Mine did the same exact thing , it took me several attempts to relearn the base idle . A lot of tinkering with the throttle body and tps but I finally got it to idle correctly.
Old Sep 26, 2013 | 08:07 AM
olddadwitsend
It holdes long enough to make you look like a dummy at a stop sigh. I have ajusted on the base idel and it is a 5 speed std.Are you droping the base idel and how much movement on the tps.Thanks
Old Sep 29, 2013 | 06:33 PM
olddadwitsend
I have taken throttle body off cleaned all of it,along with the base idel bolt. Pluged off the vacuum line that controles all the switches under the fender well. Backed off the acc. stop,and screwed the base idle all the way down. Also disconected battery.Still only if you gas on it holds at 2500 untill it decides to drop. Which by the way it always drops before I stop to open the hood !!!
Old Sep 30, 2013 | 03:50 PM
olddadwitsend
If I unplug the IACV it runs fine and check engine does not come on. Ok guy's some imput please.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
