computer
Old Apr 19, 2014 | 09:57 AM
michaela8456's Avatar
michaela8456
Default computer
can someone tell me where computer is located on 89 mustang any ideas how to tell if bad any symptoms if i hook my computer or engine check shows no codes shows ok but car has like a miss to it at idel changed distributor cap, rotor,wires,coil,plugs, cleaned maf sensor,replaced IAC,and throttle sensor,altinator,battery about out of ideas any help thanks michael
Old Apr 19, 2014 | 11:39 AM
HACKGT350's Avatar
HACKGT350
did you happen to check your plugs?
Old Apr 19, 2014 | 12:49 PM
reldla1996's Avatar
reldla1996
The computer is on the passenger side foot well, behind the plastic trim on the right side. It's not likely connected with your problem. I'd pull codes again, with a different code reader.
EZFEED
May 5, 2016 08:54 PM
piotrek53
Oct 13, 2015 06:54 PM
ChampInSD
Oct 2, 2015 04:55 AM
firecoyote
Sep 27, 2015 02:37 PM
mltdwn12
Sep 23, 2015 08:54 AM
