93 mustang T5 to T56????
Old 01-30-2015, 01:52 PM
mdolphins1334
mdolphins1334's Avatar
Default 93 mustang T5 to T56????
Currently have a 93 mustang 5.0. Building a 351w to drop in it but want more than the t5 behind it. I've been looking at kits and t56 swaps done in a fox and I know they sell for 4500 or around for everything complete. Anyone do this swap or piece parts together? Looking for options on this swap. Also not looking to spend a ton of money since I've spent a lot on this 351 build.
mdolphins1334 is offline
Old 01-30-2015, 03:27 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
www.astroperformance.com a-5 build
mjr46 is offline
Old 01-30-2015, 06:13 PM
mdolphins1334
Okay so that's one option. Then I'm left to get the bell housing and a driveshaft and longer cables. Anything else?
Old 02-02-2015, 04:24 PM
azdriveshaft
Former Sponsor
azdriveshaft's Avatar
We can help you with a shorten/lengthen on your existing shaft or build a new custom shaft. Let us know if we can help out with your build in any way.
azdriveshaft is offline
Old 02-11-2015, 07:33 AM
HACKGT350
HACKGT350's Avatar
An a5 is a beefed up t5. Better case better internals. You would be able to use the stick bell housing and drive shaft as the 351w has a taller deck hight but everything else is basically the same.
HACKGT350 is offline
Old 02-12-2015, 01:41 PM
mdolphins1334
The a 5 is just a beefed up t5 but it's still a 5 speed. I was wanting to go with a t56 for the 6 speed. But what's the difference or comparisons between a t56 and a5?
Old 02-13-2015, 09:36 AM
HACKGT350
HACKGT350's Avatar
They are completely different transmission. The t56 is a 6 speed and the a5 is a 5. However with the a5 you can opt for different first and 5th gear rations before they build it. I just installed an a5 in my buddies 90 with a 351 swap. Its a bad *** transmission and you can use all the factory mounts and bell housing. I also installed a twin disk clutch while I was in there.
Old 02-15-2015, 08:09 PM
mdolphins1334
I've been looking at different forums about the t56 and the a5. T56is definitely more expensive and more parts needed than the a5 but the a5 seems to be a good idea for the money. Some people say a t5 is a t5 and to spend the money. I'll be making around 450 he and close to the same in torque. Is the a5 the best fit for me?
Old 02-16-2015, 10:29 AM
mjr46
mjr46's Avatar
I make 550+ on a z-spec t-5 and it's held fine.........a5 depending on the level a5 you get will be fine
mjr46 is offline
StalkerGT
StalkerGT's Avatar
Could always go with a tremec tko...personally I love mine and they can handle a lot of power
StalkerGT is offline
Quick Reply: 93 mustang T5 to T56????
