SCT?
Old Nov 6, 2015 | 11:52 AM
Jly154's Avatar
Jly154
Default SCT?
Hey guys so I recently bought a 94 gt and the guy said that it had a SCT chip on it didn't know what kind when I switch stages it dosent seem to make any difference at all I took my ECU apart and cleaned connections recommended on other sights and it still dosent seen to make any difference but when I pulled everything apart on the top it read superchip but it looks identical to the SCT programmed by BAMA any thoughts?
Old Nov 6, 2015 | 01:06 PM
64bit's Avatar
64bit
Take it out and throw it away
Old Nov 6, 2015 | 01:13 PM
Jly154's Avatar
Jly154
Ok that's kinda what I was thinking about doing anyway and just going out and buying my own and get all the tunes that I want/need
Old Nov 10, 2015 | 11:04 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
what kind of mods do you have that make you think you need a tune?
Old Nov 10, 2015 | 08:29 PM
Jly154's Avatar
Jly154
It had it when I bought it but anyway it's got full ignition upgrade to MSD BBK long tubes and 70 mm throttle body full performance exhaust I'm sure I'm forgetting something but anyway I found out that it IS a SCT chip and I just bought the free tunes for life package so I can send it in and have BAMA reprogram it as I add mods
Old Nov 11, 2015 | 08:07 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Chip or tune not needed, as long as your car is maintained properly. The stock ECM does a great job at keeping an eye on the motor. Not perfect, but very close.
Is your car showing some driveability issues or just not running right ?
Old Nov 11, 2015 | 08:43 AM
mjr46's Avatar
mjr46
those aren't mods....or at least any that require tune, and bama tune for life = craptastic.....throw that subscription away as well
Old Nov 11, 2015 | 03:33 PM
64bit's Avatar
64bit
That was one of the worst things you could have ever done...
Old Nov 11, 2015 | 09:40 PM
Jly154's Avatar
Jly154
Well don there's $150 down the drain lol but anyway it ran pretty good till today I swapped the stock belt for a 82.7" belt to do away with smog pump and a/c but now it has a rough idle and sounds almost like its cammed could deleting the smog pump have something to do with that? (That was my first thought) I was planning on throwing the old belt back on tomorrow to see if it would stop idling rough
Old Nov 12, 2015 | 07:27 AM
88 orangepeel notch
Accessories and belts should have no real affect on how your motor runs/idles.
I'd look for a vacuum leak from a cracked/broken hose that might have inadvertently happened when said accessories were removed. If that all checks good, pull codes to see if they point you in the right direction.
Keep is posted on what you find.
