Headlights shorting/turning on/off intermittently
Old May 26, 2016 | 02:31 PM
6605stang's Avatar
6605stang
Default Headlights shorting/turning on/off intermittently
I've got a 1988 McLaren Mustang with 25,000 on it and today I realize that the headlights are just turning on and off by themselves... see the video below....
Any ideas what is going on? I'm terrible with electrical stuff...
Old May 27, 2016 | 09:01 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Ha, your about to get good at electrical stuff........lol
The only way to fix this is to just jump right in, start looking for shorts, broken/rubbed thru wiring, bad grounds, bad switch itself, bad connections, etc, etc.
Or pay someone a crap load of money to trace it for you.
It's OK, I hate electrical gremlins too.
From your video, I'd start by the switch and work your way forward. Wiggling, tugging the wiring till you find the short. Then repair as needed.
This is just the headlights doing this correct ?
Old May 27, 2016 | 09:14 AM
6605stang's Avatar
6605stang
Greeaaaaaaaat....
Attached Thumbnails Headlights shorting/turning on/off intermittently-200_s.gif
Old May 27, 2016 | 12:28 PM
ucinn's Avatar
ucinn
I would bet on a bad/dirty ground somewhere...That's where I would start looking anyway
Old May 29, 2016 | 09:09 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
NO ONE SO FAR IS EVEN CLOSE TO FIRST BASE ON ANSWERING THIS QUESTION CORRECTLY, that is to say you have fog lights if you do, you need to perform the TSB of wiring in a relay and taking the fog light control off of the way the factory wired it, basically all you do wire in a 30 amp relay and use the relay to power the lights and the switch to trigger the relay......if the overload has melted any wires/components such as the dimmer switch, that'll need to be fixed first.
http://www.corral.net/tech/maintenance/foglights.html
JMikk
Mar 18, 2016 02:46 PM
S2Charlie
Mar 10, 2016 04:17 PM
bradleyb
Mar 9, 2016 12:58 AM
Mar 7, 2016 05:04 PM
Mustang Videos
Mar 4, 2016 01:26 PM
