1989 Mustang no wipers but gave turbsignals
My 1989 stang has turn signals that are working but my wipers dont. I don't have power to the hot wire in fuse box either so that leads me to think the switch it out. Anybody have other opinions? It's uncommon for the turn signals to work but wipers usually they both go out since it's a multi switch.
Welcome!
There's NO power for the wiper circuit at the fuse panel? Start there and work your way towards the battery until you can restore power to the circuit. Power has to go through the fuse (or circuit breaker) before it reaches the switch. So don't blame the switch yet.
Welcome!
Tht ges through circuit breaker #2..make sure you have the car in ACC before checking for voltage at fuse since it is switched, t comes from black/light green wire from your ignition switch. check to see if you are getting that out of the ignition switch. here's the schematic for the wiper circuit. http://www.modularfoxmustangs.com/pdf/Wiper.pdf
Then ignition switch could be your problem, they don't show the individual internal switched for the ignition, but that one wire powers several different fuses, so I would think you would have other things not working also..whatever runs off fuses 6,11 & 14..it does look like there is an inline fusible link, so that can be checked by looking for power at those other fuses first..then it's all a tracing game from there.
It is possible that the switch could be bad, but it's equally possible that the wiper motor is shot, too. You won't know until you restore power to that circuit.
