Cobra injector size.
Old Aug 25, 2020 | 06:16 AM
Joe Leach's Avatar
Joe Leach
Default Cobra injector size.
I recently bought a 94 cobra roller, I bought an engine that I told was from a 93 fox body but the person told me an untruth about it, when I researched the engine out it seems to be from a 87 crown vic. The computer is set for factory 24lb injectors and I have 19s in it now but it runs really rough. Will putting 24s in with this engine help it or make it worse?
Old Aug 25, 2020 | 07:53 AM
drhoward's Avatar
drhoward
Penis Mod Erator
It should make it "better", the ecu is setup to run with 24# injectors (assuming you're using the original cobra ecu)
Old Aug 25, 2020 | 07:56 AM
Joe Leach's Avatar
Joe Leach
yes as far as I know it is. Thank you for a quick response!
Old Aug 27, 2020 | 01:20 PM
imp's Avatar
imp
5.0HOs from about '89 to '95 came with 19lb. injectors. '93 Cobra had 24#, with different Mass Air Sensor tuning, different PCM. '95-'95 Cobra I'm not sure of, as I owned a '93. Ford Motorsports sold a conversion kit which allowed use of 24# in place of 19#; kit came with Mass Air Sensor, PCM, and injectors. I used this kit to convert a '68 351W in a Mustang to EFI.
Old Aug 27, 2020 | 02:02 PM
drhoward's Avatar
drhoward
Penis Mod Erator
the 94/95 cobra's also had 24 pound injectors
billy14870
Jun 2, 2014 09:22 PM
Mike W
Mar 1, 2009 08:11 AM
WLingle92lx
May 22, 2008 09:51 PM
rlntlss
SVT Forums
Nov 6, 2007 10:05 AM
Bobbo
Sep 3, 2005 04:37 PM
