need help building windsor
Old Nov 5, 2005 | 12:03 PM
blueoval89lxcpe's Avatar
blueoval89lxcpe
Default need help building windsor
Anybody care to give me the lowdown on how I get a roller cam in my .040 351? I kept my 302 from my stang for any roller parts but, do I need to get special bearings for the cam? I know I need the spider valley to be put on the windsor but what kind of cam can I use? I am hoping to get 500 horses from my windsor!? Someone who has a windsor built for chevy duty please help Thanks....
Old Nov 5, 2005 | 12:34 PM
5.0mustang5speed's Avatar
5.0mustang5speed
I ♥ Acer
Default RE: need help building windsor
you can drill the holes in valley or you can get the retro kit roller lifter that are linked together, im guessing you are talking about a hyrdalic roller. If you dont mind a little noise and checking the valves once a month or so and really want it to run hard than go solid roller, my brother has a street solid roller in his with .618 lift , we use good poly locks and stud gridles and we check them once a week to be sure , but it has been 2 onth and they have not moved and he runs 11.70's and drives that thing to and from the track , around town , to school to work,,and has never had a problem, but a hydralic rollers are cool. they just dont make near the power a soild roller does and hydrlic roller are very heavy and are rpm limited.
Old Nov 5, 2005 | 12:36 PM
5.0mustang5speed
I ♥ Acer
i forgot , you dont need any special bearing, unless you want to spend a lot of $$$ and get roller bearing than you have to have a special cam that has a smaller radius
Old Nov 5, 2005 | 12:40 PM
5.0mustang5speed
I ♥ Acer
and also, to get 500hp from a 351 is pretty easy , we really need to know what the intended propurse of the car is for, and be truefull with your self, street -strip or strip only???? you can stroke it to a 393 or a 408, or just say with a stcok stroke, and use a good set of heads , sucj as, rpm or afr..etc...with a nice cam set up(i prefer soild roller)
Old Nov 6, 2005 | 04:54 PM
blueoval89lxcpe
sorry it took so long to post back but I would consider a solid cam in my windsor. I just want a really fast street car guys. I thought about stroking to a 408 but do I have to notch the cylinders like you do on the 302's??? Anybody got a clue what my .040 cubes out to? right bore size for the 408???
Old Nov 6, 2005 | 05:08 PM
5.0mustang5speed
I ♥ Acer
you can stroke it if you want, stock stuff is ok ,but i like the piece of mind from a forged assembly ,but it does cost more, however a well built 351 are some killer motors, it all really depends on how much cash you have. some people say use a hydrlaic cam , other like soilds , my self a solid roller is king all the way, they make more power faster and easier , my friend has a regular 351 with some wroked heads a a sloiid cam and gears and it runs 12.00 and he ****fs it at like 6000, never had any problems, we check the valves once in a while.been in there for 3 years now, shoot me an email john-dick@sbcglobal.net
bradleyb
Nov 27, 2015 07:50 PM
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
the5
Sep 19, 2015 06:13 PM
