Which Injectors
Old Nov 7, 2005 | 10:31 PM
NegadivOne's Avatar
NegadivOne
Default Which Injectors
I am building a 331 stroker, gt40p heads, e cam, with about 9 or 9.5:1 CR. It is going to be NA for now but eventually I want to add a supercharger. Should I go with 24 or 30 lb injectors?
Old Nov 8, 2005 | 12:59 AM
stanglx2002's Avatar
stanglx2002
Default RE: Which Injectors
24's thats what i have in my stroker the 30's are to big i ran rich
Old Nov 8, 2005 | 07:55 AM
Quik's Avatar
Quik
you can run with 30s with a proper tuned setup
but for that setup go 24s
Old Nov 8, 2005 | 01:04 PM
vfast's Avatar
vfast
I ♥ Acer
with a tweecer ,which you'll need if you use a S/C use can change the pulse of the injectors and use the 30's
Old Nov 8, 2005 | 08:15 PM
luckythirteen13's Avatar
luckythirteen13
id run the 30's with a dyno tune
Old Nov 8, 2005 | 08:19 PM
schwindty's Avatar
schwindty
Thats alot of COmpression for charged, if you want to run a fair amount of boost lower compression is better dude
Old Nov 8, 2005 | 08:34 PM
vfast's Avatar
vfast
I ♥ Acer
it is..I run flat tops about 9.0 with 15 psi..I'd say I'm close to the block cracking edge
Old Nov 8, 2005 | 08:42 PM
NegadivOne's Avatar
NegadivOne
Yeah its a bit steep but if i do add a supercharger it will be in 2-3 years after college. Even then i would probably only run maybe 8 lbs of boost. I dont want the compression so low that it will suck for the whole time its NA.
Old Nov 8, 2005 | 11:31 PM
silver91gt's Avatar
silver91gt
wow, 15lbs of boost, what kind of hp you making vfast?
Old Nov 8, 2005 | 11:48 PM
Quik's Avatar
Quik
9.0 is fine for compression. its actually stock. hell 9.5 is fine
you guys are so worried about little things. yes ideal CR is around 8 to 8.5 but up to 10.0 works
with a tune its safe. now if you tune a car for peak numbers it wont last, if you tune it for longivity it will last
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
MacSerio
Sep 27, 2015 01:05 PM
mltdwn12
Sep 23, 2015 08:54 AM
