need help here
Old Jan 1, 2004 | 08:04 PM
nickr182002's Avatar
nickr182002
Default need help here
im tight on cash but i need some advice. I just bought a 4 banger stang and im dropping a 302 in it. Any suggestions on which tranny i should get. Also should i keep it efi or go to carb. thanks
Old Jan 1, 2004 | 08:08 PM
89muscle's Avatar
89muscle
keep efi and get a tremec 3550
Old Jan 1, 2004 | 08:23 PM
callmecobra's Avatar
callmecobra
if your on a tight budget, dont get a tremec.... just get a stock t-5 or t-45. ide keep it efi, if the 5.0 your getting is out of the same year stang you have, or close to it. other wise you will run into probs.
Old Jan 1, 2004 | 08:33 PM
vfast's Avatar
vfast
I ♥ Acer
carb it man like I said...
Old Jan 1, 2004 | 10:06 PM
mkspeed26's Avatar
mkspeed26
it would have been cheaper just to buy a 5.0 satng than to convert to a 5.0, but whatever. pick up a stock t-5 tranny and i would go carb cause i f*ckin hate electronics</P>
Old Jan 2, 2004 | 03:22 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
CARBED ALL THE WAY!</P>
And if you want a rock hard *** kicking automatic get a C4 they will take anything you can throw at them!If its a stick go with any 87-95 V8 5speed.And stay away from early four speeds from the early mustangs theyre junk.</P>
Heres my 89 and it was originally a 2.3 EFI motor now its a 331 stroker and carbed.Its much more user friendly and cheaper to fix and modify.<IMG src=uploads/TheGmKiller331/5EA4C_gmk5.JPG border="0"></P>
Old Jan 2, 2004 | 03:23 AM
TheGmKiller331
I ♥ Acer
By the way i am using a C4 behind the 331 and i love getting on it and its as good as new.It has s**tty mileage on the highway though because its a 3 speed and i have 3.73's out back.But hey f**k gas mileage.
Old Jan 2, 2004 | 03:26 AM
BLKSTANG9879's Avatar
BLKSTANG9879
If your tight on money go with a carb. The T56 tranny is nice.
Old Jan 2, 2004 | 06:17 AM
TheGmKiller331
I ♥ Acer
reguardless of money go with carb in my opinion.EFI is a total bitch to install.I know me and buddy swapped in a used 95 cobra motor in an old 88 lx 2.3 convertible.I never wanted to beat the s**t out of an object more than with that car.It wasnt hard just very time consuming.</P>
</P>
This wasnt a plug and play either he wanted this done on a low budget.We wired from the computer up and belive me it was a pain in the ***.I am sure with the actual donor vehicle and all the direct hookups it would be easier.</P>
Old Jan 2, 2004 | 04:07 PM
mkspeed26's Avatar
mkspeed26
carbs are sweet. then you dont have to worry about all the mass air sh*t and injector sized and sensors, you just have to tune it and then put the peddle down to the floor!!! <IMG src=smileys/smiley16.gif border="0">
