I have just received my trickflow top end kit and I am waighting on my 75mm mass air and cold air induction to be deliverd . I also got a set of 24lb injectors and the other stuff I need to install this kit on my 94 GT . How do I go about drilling the oil fill hole and what advice and experiance do all of you mustang people have?
yes the hole in the valve covers ! Trickflow sells a kit that is an oil fill kit for the valve covers but you have to drill the hole and install the kit your self. Just woundering if anyone else has done this and what size bit did they use and how did it turn out?
i used a drill bit on mine 1st & then enlarged it with a drimel. i got the trick flow oil fill kit it is about $25 but i t looks good & works good too. good luck.
i have the tfs kit on & like it . every thing fit & if you like ,you could exchange a few items like cam size & track heat intake in stead of street heat intake & silver or black intake & valve covers, etc.
