Cooling system help is needed...
i just completed a 3.8 to 5.0 swap in my sn95 and i was driving down the street and i turned on my heater blower and POOF... coolant vapors filled the car and the engine freaked out... and blew off the upper radiator hose, dumping coolant all over my nice new clean shinny 5.0. now... i checked the thermostat... its fine. i know for a fact that it wasnt full with coolant. so im assuming the air pockets heated up and expanded... thus causing the hose blow off. but... would that kill my heater core? now when i try to burp the radiator to fill it, the coolant surges out the cap openning... then drops about 4 inches. then 3 seconds later it surges back up and spills out coolant, then drops again. any thoughts?
r u running the correct rotation waterpump?did u blow a head gasket? are the hose clamps to the core tight?go to auto zone and get the loan a tool coolant pressurizer to look for problems if ur core is bad have fun i just did mine on my 91 gtvert whole dash had 2 b taken apart dont know about sn95 tho
JUST did head gaskets last night. before problem came up. it is the correct rotation. it ran fine before i did the head gaskets. and yes i did put them on the right way... if your going to ask. and the clamps ARE tight. no doubt.
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
