13s???
Old Nov 26, 2005 | 05:44 PM
BlackSVTsnake302's Avatar
BlackSVTsnake302
Default 13s???
I have a 1994 SVT cobra, I no the cars good for a solid 14s bone stock, so what would I need to see into the 13s w/ out doing a supercharger or heads??? Im thinking nitto 555r Drs, 3:55s, 70mm BBK throttle body, and ebay CAI. Just want to get into the 13s this summer but I dont have much money, please help me out! thanks
http://www.cardomain.com/ride/808175/1
Car Domain ^
Old Nov 26, 2005 | 09:00 PM
Crazyfast50stang's Avatar
Crazyfast50stang
Default RE: 13s???
doesnt your car come with 3.27 gears stock? Go for 3.73 and get a proffesional products tb off ebay. Save you money. Then with the money you save lower your car to get better traction. I know you said your getting the nitto's but with stock suspension hooking will still kind of suck especially with the gears. Advance your timing and get an exhaust. How much are you looking to be spending? 1K? Less? More?
Old Nov 26, 2005 | 09:01 PM
razarr69's Avatar
razarr69
Default RE: 13s???
Dont lowering springs make your car have ****tier traction? I got a set of eibach drag launch springs, wouldnt he be better of with this istn of lowering. Also control arms will help alot too.
Old Nov 26, 2005 | 09:02 PM
razarr69's Avatar
razarr69
Default RE: 13s???
Old Nov 26, 2005 | 09:03 PM
Crazyfast50stang
Default RE: 13s???
Havent heard of it making it ****tier but you may be right. Some one here will be able to straighten it out.
Old Nov 26, 2005 | 10:16 PM
w8less's Avatar
w8less
Default RE: 13s???
get some upper and lower control arms and a good set of tires like the drag radials mentioned and should be be able to hit the 13's
Old Nov 27, 2005 | 12:25 AM
rsw007's Avatar
rsw007
Default RE: 13s???
gears and tires not nittos for track though. go with mickeys if its not your daily driver. lowering the cars supension will help its geomtry but you need loose springs in front. i run lowering springs in rear and cut drag springs in front.
Old Nov 27, 2005 | 03:01 AM
BlackSVTsnake302
Default RE: 13s???
My car has 3:08 gears stock, and yeah under a grand?? also, having trobles finding that tb on ebay? some help would be nice
Old Nov 27, 2005 | 04:15 AM
88BlueGT's Avatar
88BlueGT
Default RE: 13s???
gears + minor suspension + exhaust + timing = without a doubt 13's.
Old Nov 27, 2005 | 04:52 PM
BlackSVTsnake302
Default RE: 13s???
Timing? What is that and how do you do it???
