disassembling fox
Old Nov 27, 2005 | 02:11 AM
91lxstang's Avatar
91lxstang
Default disassembling fox
ok..... im gonna start to dissassemble my car this christmas because im havin it painted and i need sum tips... i need to know how to take off the window trim and the quarter glass....also my suspension is drivin me crazy! it squeaks and rattles and just sucks so im gonna completely rebuild my suspension.... i need to know what good companies make good bushings and so on.... i already know what springs and rear control arms i want ...... and what shocks should i use? any other ideas on what to upgrade? keep in mind that i dont have tons of money
Old Nov 27, 2005 | 03:05 AM
SchoolBoy's Avatar
SchoolBoy
Default RE: disassembling fox
I am fairly sure you will need to remove your rear quarter pannels, and the trim that is inter laced with them... Some of the upper trim around the doors, winsheld, and the big pice that captures the rear of the head liner are all snap in with mettal clips, but be sure to double check for any screw's.....
As far as bushings go, I used Energy Suspension on my capri, and they seam to be holding up fine.... and I don't belive they are too expensive either..... http://www.energysuspension.com/
Hope that helps some.....
Old Nov 27, 2005 | 03:06 AM
91lxstang's Avatar
91lxstang
thanks man
Old Nov 27, 2005 | 04:06 AM
88BlueGT's Avatar
88BlueGT
To take off your quater trim. You need to remove your interior quarter panels (i also took out my back seats... it just made it easier) and than once you remove them there are nuts holding the trim in. Im not positive but I think there was 10 or so on each side. Very simple to remove. Take the nuts out and remove the window. There is some kind of sealant holding the trim onto the quarter of the car. I just took a knife to it and pulled it off. Not hard at all. Just kind of time consuming.
Old Nov 27, 2005 | 04:07 AM
88BlueGT's Avatar
88BlueGT
Let me know if you have any other q's about the interior. I just stripped my whole car about a month ago so its still fresh in my head if you need help
Old Nov 27, 2005 | 09:54 AM
stanglx2002's Avatar
stanglx2002
you should upgrade all your bushings to poly bushings most aftermarket parts you will get will have them. this will help some with the squeaking but to stop the sqeaking you need to sniffen the body with subframe connector, strut tower brace, and lower control arms.
Old Nov 27, 2005 | 01:39 PM
91lxstang's Avatar
91lxstang
do you know where to find a complete poly bushing kit cause i couldnt find any prices on energysuspension.com and i didnt see any poly bushings on there but i just woke up so i probably just missed it
Old Nov 27, 2005 | 01:54 PM
91lxstang's Avatar
91lxstang
i found a prothane kit? is this any good cause i dont want squeaks
Old Nov 27, 2005 | 03:35 PM
SchoolBoy's Avatar
SchoolBoy
If you can post a link to the kit that you found it would be a help.........
As for not finding anything on E/S try this link.......Mustang's Just write down the part numbers you need, then call up auto zone or a local speed shop and see if they can order the stuff for you....
Also you might want to read this artical......Fix that suspension!
Old Nov 27, 2005 | 04:11 PM
88BlueGT's Avatar
88BlueGT
You can find full poly kits in summit, jegs, yearone, etc. Not too hard to come by...
