tranny mounts loose?
Old Dec 9, 2005 | 01:13 AM
RumbleBee89gt's Avatar
RumbleBee89gt
Default tranny mounts loose?
i think either my tranny is fu&ked up, or its loose.i have a short shifter and a hp cobra clutch, when im in like 3rd gear and i tap the gas, the car will jerk and i hear the tranny make some kind of noise,likes its loose and moving back and forth. Then on the freeway, my car shakes really hard. It feels like its coming from the tranny becuase the shift boot is shaking. any help will due, thanks,late
Old Dec 9, 2005 | 01:17 AM
cammedlx's Avatar
cammedlx
Default RE: tranny mounts loose?
Check your universal joints on the drive shaft,or you u/l control arm bushing's could be shot....
Old Dec 9, 2005 | 01:24 AM
RumbleBee89gt
can i get some info on how to check any of those??thanks.
Old Dec 9, 2005 | 01:27 AM
cammedlx's Avatar
cammedlx
Well the universal joints just get under the car with it in gear and grab the driveshaft,if there is any up and down or side to side play they are bad,with the u/l control arms its really hard to tell unless you remove them to inspect the bushings completely...
Old Dec 9, 2005 | 01:30 AM
ZachW04Stang's Avatar
ZachW04Stang
Could be worn out motor mounts or tranny mounts. My motor mounts and tranny mounts are shot and once I hit 65mph and cruise the car shakes. To check bushings and mounts if they are really dry and cracked or have pieces missing then they are shot.
Old Dec 9, 2005 | 01:35 AM
RumbleBee89gt
ok thanks everyone, im gunna check tomarow and see what it is. the tranny doesnt grind, but could it be the tranny going out?i really hope not.late
Old Dec 9, 2005 | 05:06 PM
RumbleBee89gt
ok today i lifted the car and checked the drive shaft, its very loose.i can move it up down side to side very easy, what do i need to replace??is it cheap?easy?thanks.late
Old Dec 9, 2005 | 10:40 PM
nitrous_bob's Avatar
nitrous_bob
up , down, side to side???
try rotating it in gear...back and forth.....the way you described it sounds like a bad bushing in the tailshaft.
either way fairly ez fix, u-joint is ez'er though so hopefully thats it.
Old Dec 10, 2005 | 01:35 AM
RumbleBee89gt
yea when it was in gear, i moved it up down, and back and forth, it turned alot.should i replace the tail bushings and the u joint?the u joint is the one that connects the drive shaft to the tranny right?if so, that is definatly bad. are the u joints on summit good?thanks.late
Old Dec 10, 2005 | 02:23 AM
cammedlx's Avatar
cammedlx
ORIGINAL: nitrous_bob
Bad bushing in the talishaft?????And you question my theroy please go back to pipe,boost and juice...And speak about your little dry kits.
