new engine
Old Dec 9, 2005 | 07:36 AM
shift
Guest
Posts: n/a
Default new engine
what would be the most reliable and most powerful motor i can get away with for my '89 5.0?
i want to be able to go to the track and race all day and then go to cruse night and not have to worry about anything
please help me i am open for suggestions
Old Dec 9, 2005 | 09:24 AM
RacerX's Avatar
RacerX
Default RE: new engine
same specs. and info I gave my engine builder at FORD PERFORMANC SOLUTIONS,in ANAHEIM,CALI. they recomended a 347 for me. It's naturally asperated with 10.5 to 1. HP=500 and 500 ft.lb. of torque. Good luck!!
Old Dec 9, 2005 | 09:25 AM
RacerX's Avatar
RacerX
also more cubic inches requires less stress on motor to produce power.
Old Dec 9, 2005 | 10:28 AM
stanglx2002's Avatar
stanglx2002
it depends on how much HP you want and if it will be seeing a power adder. The best thing to do is build the engine from the ground up and if you are looking to get higher then 500 hp you need to get a better block maybe a R302 block and build a 331 stroker or get a 351 block and build a 408. If you are going to add a SC to the car you need a low compression engine like 8.5 to 1 or if you are going to stay NA then 10 to 1 would be a good compression
Old Dec 9, 2005 | 11:45 AM
TAPOUT's Avatar
TAPOUT
I just had a 347 built for my car...Should be the best easy way to go.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
