idle problem
Old Dec 13, 2005 | 02:05 AM
RumbleBee89gt's Avatar
RumbleBee89gt
Default idle problem
hey im having an idle problem. it jumps from .5 rpms up to 2 rpms. always fluctuating never stays at a certain rpm. i have a brand new idle sensor, and brand new TB gasket. any ideas??thanks.
Old Dec 13, 2005 | 02:09 AM
Crazyfast50stang's Avatar
Crazyfast50stang
Default RE: idle problem
maybe some sort of out of wack vacuum leak that will clog then unclog?
Old Dec 13, 2005 | 02:12 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
do u have a k=n conical filter?
Old Dec 13, 2005 | 02:13 AM
RumbleBee89gt
not sure, the car came with a mac intake. not sure about the filter. could be a k&n.could it be the air flow meter?
Old Dec 13, 2005 | 02:19 AM
Erik90LX5.0's Avatar
Erik90LX5.0
I had a similar problem mostly would idle very low and rough. Found vacuum line from under upper plenum goes froward to vapor cannister it was soft and rotted out .Hope it helps
Old Dec 13, 2005 | 02:24 AM
RumbleBee89gt
thanks for the help, im gunna check the vaccum lines tomarow,does anyone have a link to where i can find a vaccume line diagram?
Old Dec 13, 2005 | 10:00 AM
vfast's Avatar
vfast
I ♥ Acer
clean the maf
Old Dec 13, 2005 | 02:10 PM
RumbleBee89gt
your supposed to clean the maf with carb cleaner right??or just wipe it out?
Old Dec 13, 2005 | 02:41 PM
Djs94stang's Avatar
Djs94stang
No, alcohol and a cotton swab.
Old Dec 13, 2005 | 03:29 PM
RumbleBee89gt
ok,i cleaned the maf.didnt help.cant find any vac leaks. does anyone have a chart of the whole vaccume chart?
