missing problem.. fuel imjectors?
Old Dec 14, 2005 | 07:39 PM
Fastman's Avatar
Fastman
Default missing problem.. fuel imjectors?
so i got this mustang a few weeks ago and now the dam things is acting up..... i bought a new fuel pump and filter, the filter was brown, and it's still missing, so i just ordered 24lb/hr injectors, will i need a better fuel pump.
p.s. it's getting spark and everything, just missing alot at low rpm..
advice??
Old Dec 14, 2005 | 07:42 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: missing problem.. fuel imjectors?
I wouldnt' waste money on larger injectors unless you are planning on upgrading other things in the near future. Waste of money. You are getting spark but is the spark making it into the cylinder? When you say at low RPM, is that under a load as in while driving it?
Old Dec 14, 2005 | 11:34 PM
nitrous_bob's Avatar
nitrous_bob
try closing the plug gap way down to about .035...if it runs right you have a spark issue.
my guess is the distributor module, or coil, or plugs or cap or rotor or plug wires........
Old Dec 16, 2005 | 01:30 AM
Fastman's Avatar
Fastman
yah it gets spark at the plug!? yeah it misses like when i'm just cruising, when i step on it it's pretty weak but can't feel it miss in the same way as if a plug wire wasn't on, just sputters while cruising, im gona try a ignition module tomorrow
Old Dec 16, 2005 | 01:57 AM
ZeroSk8er823's Avatar
ZeroSk8er823
Wow sounds like my problem. Read my post and see if it sounds similar. "Car stumbles bad(misses) occasionally." prob on this same page.
Old Dec 16, 2005 | 07:17 PM
Fastman's Avatar
Fastman
NOT THE IGNITION MODULE, gona put new fuel injectors in soon, plus a cam and other ****
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
mrappe
Sep 26, 2015 10:16 AM
