electric fan help
Old Jan 12, 2004 | 09:33 PM
1992 schp's Avatar
1992 schp
Default electric fan help
i don't want it to run all the time. whats the best option? i want it to run only at 30 mph or less. how can i do that?
Old Jan 12, 2004 | 09:36 PM
BLKSTANG9879's Avatar
BLKSTANG9879
You should want it to run by the temp not the MPH.
Old Jan 12, 2004 | 09:53 PM
1992 schp's Avatar
1992 schp
been there. done that. want to be a little different. the air temp stays cool around here so i won't have any cooling problems.
Old Jan 12, 2004 | 10:13 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
The only two options you have are to run a thermostatic switch and or run it off a toggle switch.Im not sure why you want to be different in that area but if you come up with a way to monitor your speeds and kick them on drop a thread im curious as to how you would do it.But i still wouldnt run it by speeds even if you could
Old Jan 13, 2004 | 01:40 AM
Quik's Avatar
Quik
have fun finding a way for it to monitor speeds. your best bet is to do it manually. if not get a VSC. that controls fans to come on by temp
Old Jan 13, 2004 | 11:13 PM
1992 schp's Avatar
1992 schp
thanx
Old Jan 14, 2004 | 12:10 AM
vfast's Avatar
vfast
I ♥ Acer
you could do it off engine speed using a crank trigger system...
can do I have to alway be the creative one*L*
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Seanam
Oct 4, 2015 10:15 AM
mrappe
Sep 26, 2015 10:16 AM
Sep 25, 2015 09:06 AM
