Transmission
#22
Transmission
Hello all T-5 made after 1986 or something like that is a worldclass T-5. the ones they sell in the magazines is a close ratio 2.95:1 ratio 1st world class (stock isa3.35:1 1st) open it up it is the same exact transmission including the size of the gears. what makes the 2.95 ratio stronger is that it is a less of ratio. Get a tremec 3550 about 400 less than a tko rated at 350lb/ft(underrated)guarnteed to handle enough power to lift the front tires off the ground but it is still priced around 1200-1300 plus a different bellhousing. If buying a TKO 1800$+ plus bellhousing , plus a different clutch requied for TKO(3550 same as t-5) A tremec 3550 will be plenty into the low 11's and 10's
#23
Transmission
some world class t's have straight cut gears which is what I like to have but I run a tremec in my high hp car..milkey like I said there is alway something better but with less than 1k your options get limited so the tremec would be the way to go under 1k
#25
Transmission
If the 3550 handles so much that sounds great, but how much difference is there from the T5 then? I wonder whether I should stick with the T5 and rebuild or go with the stronger (I think) tremec.
#26
Transmission
why do you like the straight cut? the only real difference in the wc t-5 is that there is clutch-like material on the synchro's that make them mesh better</P><edited><editID>FiveOhNo</editID><editDate>38005.5253587963</editDate></edited>
#27
Transmission
straight-cut gears dont mesh as well and it is easier to grind them. dont know what the positives of straight cut gears are though</P>
#30
Transmission
i would say go with the g-force rebuild kit i'm pretty sure they hold up to 500hp. if you want to know more i think it was 5.0 mag had an article about the kit within the last like 5 issues....if it's not 5.0 mag then it's like the superfords or whatever...i get them all confused cause i get them all in the mail
