Compresion check???
Old Dec 22, 2005 | 12:02 AM
Tims 88GT's Avatar
Tims 88GT
Default Compresion check???
Hello everyone i did a compresion check and im hoping someone can help me i thought each cylinder should be about 140 or so but this is what i got i just wanted to know if that is ok thanks everyone
115-4 8-115
130-3 7-115
125-2 6-110
115-1 5-110
Old Dec 22, 2005 | 12:33 AM
Tims 88GT's Avatar
Tims 88GT
Default RE: Compresion check???
oh come one i know someone knows this, vfast, quik someone help me out here
Old Dec 22, 2005 | 12:59 AM
Tims 88GT's Avatar
Tims 88GT
talk to ya all later
Old Dec 22, 2005 | 07:32 PM
69mach1377's Avatar
69mach1377
Seems kind of low, but at least its consistent except for #3. They should all be like him or better IMO. Mine average about 165-170 psi.
Old Dec 22, 2005 | 07:35 PM
Tims 88GT's Avatar
Tims 88GT
now how much does your cam have to do with it? any at all i have a really short duration.
Old Dec 22, 2005 | 11:28 PM
86gt5.0HO's Avatar
86gt5.0HO
Those readings are low. Did you have the throttle held wide open when testing?
Old Dec 22, 2005 | 11:31 PM
5.0 MPG's Avatar
5.0 MPG
Yea thos deffinately look low. Do you have a Chilton's? You ought to check what the range should be.
Old Dec 22, 2005 | 11:33 PM
Tims 88GT's Avatar
Tims 88GT
great now im starting to feel bad, no the trottle was not wide open or anything, i need to check the seals on my compresion checker, the thing that makes me mad is it only has like 1500mi on the freaking thing it does not burn oil or anything
Old Dec 23, 2005 | 12:41 AM
SchoolBoy's Avatar
SchoolBoy
Ya something isn't right there, do you notice it not having the power it should? When I did the compression on the capri, all cylinders came out to 110, every last friggin one, at least it dosen't burn oil yet. But that is to be expected of an all orignal car with 192,000 miles on it! I say that you should do the check again and see what happens....
Old Dec 23, 2005 | 12:50 AM
frop's Avatar
frop
What's your static compression?
Edit: Also, where the bores honed right for the type of rings you're using?
