smog pump woes
i believe the source of my squeaking was from the smog pump, as it reached the height of its annoyance last night before seizing up and burning/snapping the belt, this was on the 57 freeway through placentia/orangethorpe ave. am i supposed to be able to turn the smog pump pulley freely? it is locked stiff at the moment...</P>
what are the effects of bypassing(for now) the smog pump on a stock SD motor, and whats an easy quick way of doing it?</P>
the old smog pump sounded like a box of nails when i took it out, i just got another smog pump and stock belt size, i dont want to hassle with emissions passing......how do i correctly reinstall the stock belt tensioner... <edited><editID>bmorrisj</editID><editDate>38000.7500462963</editDate></edited>
the pump should spin freely. I bypassed mine. If you are worried about emmisions it willpass the tail pipe test with the pump eliminated. they could give you a hard time ifthe pump is not physicly there. if you already put a new pump in just run the short belt. The connect the long belt when you get it inspected<IMG src=smileys/smiley1.gif border="0">
well the only 2 things i can tell ya that will happen by eliminating the smog pump is.... 1)a lil more hp</P>
2) if you have catlytic converters itll gut em out for you lol..... thats only ater about 4 months or so though</P>
also someone tell me real quick is it easy to take out the smog pump? cause i already have a way to pass e-check and dont want it in my car.. its making an annoying noise... so is it hard to take out
