starting problem
Old Jan 4, 2006 | 01:19 PM
jj86's Avatar
jj86
Default starting problem
hey i got a 86 5.0 and iono why it does this but sum days i could turn the ignition and the car will start right with no problem but on other days it won't start up at all so i got a ignition button to were i could just push that button the car will start right up but now that button tries to start the car when im not in the car and when im driving so now i gota take the ignition button and i can't depend on turn the key to start the car up because it works sumtimes and sumtimes it don't at all so is there any way i could fix that turning the key problem can any1 help thanx?
Old Jan 4, 2006 | 01:23 PM
schwindty's Avatar
schwindty
Default RE: starting problem
Ya lost me there dude, you want to know what?
Old Jan 4, 2006 | 01:30 PM
jj86's Avatar
jj86
i wanna know wat is the problem with the ignition sumtime it works and sumtimes it don't work wat could that be
Old Jan 4, 2006 | 02:50 PM
schwindty's Avatar
schwindty
Ignition itself possibly, the starter soloniod, ground wires. Check them all working from ground wires to the ignition.
Old Jan 4, 2006 | 03:32 PM
jj86's Avatar
jj86
aite thanks
Old Aug 24, 2007 | 10:29 AM
72MACH1_92LX50's Avatar
72MACH1_92LX50
https://mustangforums.com/m_3732765/...tm.htm#3732765
I have the same problem. I'm going to check my ground wires today...
Old Aug 25, 2007 | 08:37 AM
72MACH1_92LX50
ORIGINAL: 72MACH1_92LX50
All of my ground wires are OK?
Old Aug 25, 2007 | 09:13 AM
creekrat's Avatar
creekrat
Hey jj, one good book that will help you out with your problem.. Check it out. It's called Websters. It may not help you out with your starting problems, but it will surely help you outwithyour spelling problems.Also, punctuation and capitalization helps in communiacting your message. I read your post several times, and all I wanted to do was punch you in the nose.
Old Aug 25, 2007 | 01:15 PM
redneck racer's Avatar
redneck racer
try changing the ignition switch... mine wouldnt start sometimes and would do weird electrical things and after that 10 dollar part i had things working that never worked before.
Old Aug 26, 2007 | 09:04 PM
72MACH1_92LX50
ORIGINAL: redneck racer
I changed my ignition switch and I still have the same problem?[]
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
