fuel pump
Old Jan 18, 2004 | 05:24 PM
face1028's Avatar
face1028
Default fuel pump
when is it time to bump up your fuel pump. will the stock one deliver enough for 24 lbs injectors or should you jump up to 190 lbs pump. with the 190 lbs pump make a pretty much stock stang run rich??
Old Jan 18, 2004 | 05:45 PM
Jugador1's Avatar
Jugador1
I ♥ Acer
Default fuel pump
i think it just is capable of delivering more, but i dont think it will deliver its full capability...get it? lol
Old Jan 18, 2004 | 06:41 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Default fuel pump
If your combo is in your dignature then you dont need to upgrade the stock pump is more than enough.
Old Jan 19, 2004 | 01:25 AM
face1028's Avatar
face1028
Default fuel pump
I am thinking of putting 24 lbs injectors in bigger tb and mas. will the stock pump still work??
Old Jan 19, 2004 | 01:56 AM
TheGmKiller331
I ♥ Acer
Default fuel pump
yeah those arent big mods.I think you are just fine running the stock equipment.
Old Jan 19, 2004 | 01:58 AM
BLKSTANG9879's Avatar
BLKSTANG9879
Default fuel pump
A big pump will never hurt. What size are you planning on using?
Old Jan 19, 2004 | 12:30 PM
mkspeed26's Avatar
mkspeed26
Default fuel pump
wait until you need a bigger pump</P>
Old Jan 19, 2004 | 01:57 PM
BLKSTANG9879
Default fuel pump
Yea! There are alot of other things you can spend your money before you even have to think of getting a bigger fuel pump.<IMG src=smileys/smiley4.gif border="0"></P>
Old Jan 21, 2004 | 11:06 AM
face1028's Avatar
face1028
Default fuel pump
I bought a 190 lbs but I am thinking of returning it and getting a short throw shifter
Old Jan 21, 2004 | 12:09 PM
Glengemen's Avatar
Glengemen
Default fuel pump
</P>
On an otherwise stock engine a bigger TB will cause you to loose power. Thet is one of the mods that comes after the engine requires more air, such as stroking, forced induction of any kind, of even a good port and polish job. I would worry more about the intake manifold and exhaust system. Both of them suck stock. On a 5.0 you get respectable gains for about the same cost instead of loosing power.</P>
