Bad Vibration
Old Jan 7, 2006 | 12:39 AM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: Bad Vibration
Why not try a simple tire balancing. Will cost you $20 and just tell who ever does it to look for a bent wheel.
Old Jan 7, 2006 | 06:36 AM
MustangSaleen1's Avatar
MustangSaleen1
Well when I bought my mustang it had a bad vibration too. I found out that it was my fan clutch. I thought it was my tranny but when it came apart and busted my water pump, thats when I found out that was the problem.
Old Jan 7, 2006 | 07:05 AM
Black Snake's Avatar
Black Snake
Does it back fire at all? Checked the tranny mount?
Old Jan 7, 2006 | 12:49 PM
stanglx2002's Avatar
stanglx2002
i will check the fan tom
Old Jan 7, 2006 | 01:07 PM
angcobra's Avatar
angcobra
I am still trying to understand if it vibrates when you rev in nuetral, if that answer is no, you are not looking for something with the engine.
Knowing specifically it vibrates; in neutral, in all gears, only at some highway speed in grear, at highway speed in neutral, needs to be known to pin it down.
ORIGINAL: stanglx2002
Old Jan 7, 2006 | 01:15 PM
stanglx2002
its in all gears as soon as he hits 2500 and up it vibrates
Old Jan 7, 2006 | 10:31 PM
angcobra's Avatar
angcobra
What if you are in neutral?
Old Jan 7, 2006 | 10:35 PM
Suspect's Avatar
Suspect
driveshaft??
Old Jan 7, 2006 | 10:57 PM
RacerX's Avatar
RacerX
what happens if you put it in netrual after you reach the 2500+rpms. This will tell you if if does it under load or not.
Old Jan 8, 2006 | 01:13 PM
stanglx2002
ORIGINAL: RacerX
i did that and no vibration so its in the engine compartment
