Fuel pump
Old Jan 19, 2004 | 04:44 PM
Milky's Avatar
Milky
Default Fuel pump
What size fuel pump should i be getting for my car? Ive got intake heads cam exhaust 24lb injectors and minor stuff. </P>
thanks</P>
Old Jan 19, 2004 | 06:34 PM
mkspeed26's Avatar
mkspeed26
Default Fuel pump
im pretty sure the stocker will work
Milky's Avatar
Milky
Default Fuel pump
Well my fuel pump i suspect is going bad, so I need to replace it but im not sure which lph.
Old Jan 19, 2004 | 06:35 PM
Black Horse's Avatar
Black Horse
Default Fuel pump
255 lph
Old Jan 19, 2004 | 06:38 PM
bmorrisj's Avatar
bmorrisj
Default Fuel pump
and pick up a S/C while your at it...
Old Jan 19, 2004 | 06:39 PM
horatio102's Avatar
horatio102
Default Fuel pump
If it's going bad, buy one and anticipate for future modifications - get the big one (255 like BH said). If it's not going bad, don't worry about it.
I assume you've already got an adjustible fuel pressure regulator? I know the 30lb injectors like a bit more pressure than stock, and I'd assume that the 24's would be somewhere in between.
Old Jan 19, 2004 | 06:41 PM
Milky's Avatar
Milky
Default Fuel pump
Isn't 255 a bit much? s/c?
Old Jan 19, 2004 | 06:42 PM
Black Horse
Default Fuel pump
it'll be fine
Old Jan 19, 2004 | 06:48 PM
mkspeed26's Avatar
mkspeed26
Default Fuel pump
im thinkin 255 is too much unless you are plannin on somethin big, and soon
Old Jan 20, 2004 | 03:34 AM
Milky's Avatar
Milky
Default Fuel pump
Im agreeing with that, a lot, so what size is about right. 155 sound alright? too much? too little? mind the mods... AFR185 heads and bigger cam to come btw... </P>
I get this bumping sound (bad combustion maybe?) and it chokes the engine for that one explosion which I think is fuel not getting to the cylinder, or enough. So Im going to replace the fuel pump. </P><edited><editID>Milky</editID><editDate>38006.0663773148</editDate></edited>
